    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Ehouse Feeling the Heat
    Upstate NY
    I have a very nice weso tile stove model 020, the smallest one. The exit flue has an ID of 4 3/16". The Chimney is 6" Class A. I need to have an adapter pipe fabricated to connect to black pipe. Should I run 4" black pipe from the adapter to the chimney reducing the flow slightly, or go to 5" and reduce at the chimney, or go right to 6" off the stove adapter? I'd rather stay small for clearance reasons. Thanx.
    Ehouse
    #1
    Helpful Sponsor Ads!
  2. begreen Super Moderator
    South Puget Sound, WA
  3. Ehouse Feeling the Heat
    Upstate NY
    Sorry, my main concern isn't the adapter but the pipe sizing. How will it affect things if I run 4" up to the 6" chimney as opposed to adapting to 6" right off the stove? I'd like to use 4" for clearances.
    Ehouse
  4. begreen Super Moderator
    It should work ok to use the same outlet size pipe for the connector as long as the run is not extremely long and horizontal sections have an adequate uphill pitch.
