what is a Cigar burn
James02 Posted By James02, Jan 17, 2012 at 12:02 AM
  1. James02
    James02
    Feeling the Heat 2.
    NULL
    Aug 18, 2011
    346
    29
    Loc:
    L-Town...N.Y.
    Please explain....thanks!
  2. oldspark
    oldspark
    Guest 2.
    NULL
    Burning the wood from one end to another by rakeing the coals forward, first time I heard the term was from a book I read about wood burning 30 years ago, it was refering to the kind of burn you get with the baffle stoves.
  3. James02
    James02
    Feeling the Heat 2.
    NULL
    Aug 18, 2011
    346
    29
    Loc:
    L-Town...N.Y.
    I saw what you posted in a previous...post. I was thinking it was some way of getting a slow burn. Thanks!
  4. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,902
    8,631
    Loc:
    South Puget Sound, WA
    I've heard the term used to describe the front to back burn one gets with box stoves like the old Upland 27, Jotul 602 and in particular the 118. Though perhaps it applies to any N/S burn?
    "A good Scandinavian woodstove like the Jotul 118 burns logs from end to end like a cigar, and forces the air inside the stove into an S-shaped pattern, thus ensuring complete combustion. It achieves this at a near constant temperature throughout the burning cycle. Some Scandinavian woodstoves are constructed of cast iron, instead of the sheet steel used elsewhere. The Scandinavians have a long experience in this field, and claim that iron retains heat longer and distributes it more evenly than steel. Further, that it will last better."
    The Woodburning Book - David Thear
    http://www.alternativetechnology.info/woodburning.htm
  5. egclassic
    egclassic
    Feeling the Heat 2.
    NULL
    Jan 1, 2011
    261
    15
    Loc:
    SW Ohio
    I must be doing something wrong! Every time I try to get the cigar burn going, it's not long and the whole box is ablaze.
    I guess it's because the front ends of the splits are propped up on the coal bed which leaves just enough room under the splits for the air to get through.
    Try, try again!
