whitfield advantage I control boards
fresnostove
3
western
Does anyone know why these baords light up like a christmas tree then shut down. Is there any way you can pull apart to clean? I have seen this on three stoves. The board lights up when start pused, then it goes out. Is there a link for cheap priced boards?
Is this a pellet stove . . . or a wood furnace or boiler . . . if so you might have better luck posting in those forums. If this is a woodstove . . . uh . . . I don't know.
Sounds like you have a bad control board. Sorry to tell you, but you have to buy a replacement board from Lennox. These boards have pre programmed IC chips. Know one makes a cheaper replacement board. I hope you use a surge protector. I've looked in to repairing these board, but without the pre-programmed IC chips, your screwed.
