Yup, normal. your wood is not yet fully seasoned.
The inexpensive moisture meters often top out at 35% indicated. if you happen ti have one of those the correct term for what you have now is 35% or more.
The term "seasoned" in an ad is meaningless. There is no standard for it, like there is for a "cord". What you would have to do is negotiate with the supplier that you require an internal MC of around 20%. You can probably get away with up to 25% if you need to. But I think what you will find is that very few suppliers will guarantee that. If they do, expect to pay more because it costs them a lot to adequately dry the wood before delivery.Thanks! What is the best way to know if I am buying well seasoned wood, besides the ad saying "seasoned"?
Yes. If you do want to use a meter on cold or warm days, here is a chart to make necessary corrections to the meter reading for a range of temps:I would add your moisture meter is likely calibrated for wood at +70dF.
question: i know i always see the "fresh split and room temperature" requirement for moisture meter use. so, do you bring the wood inside, let it get to room temp, go outside and split, and then test?
I bring it in for 48 hours, split it wherever and measure the fresh faces. ten minutes outdoors is not going to refreeze what took two days to thaw.question: i know i always see the "fresh split and room temperature" requirement for moisture meter use. so, do you bring the wood inside, let it get to room temp, go outside and split, and then test?
Depending on the temperature and the species, it's probably okay if not ideal. That's what I burned my first season. It was iffy and caused a little glass darkening and a little light creosote on the chimney screen. It will be better next year for you. See the charts I posted in post 9. If the reading is 25%, it could actually be higher than that. My experience is that 25% is kind of a tipping point and gets more problematic quickly after that.is that 23-25 range to wet to be burning this season?
Wood should be tested when at room temp, not outside unless it's summer. 23-25% is a bit damp. If you can bring it into the house for a few days before burning that may help.(newb here) I just got my first cord of "seasoned" wood in Georgetown, Massachusetts. I got a moisture meter today and when going outside to test wood i'm getting 23-25%. I'm going to bring some in and split tomorrow to see but is that 23-25 range to wet to be burning this season?
And split it small to increase the surface area exposed. Putting it in front of a slow fan may help too if you have room for a few days worth. You may have heard of people putting it next to or even on top of the stove to dry faster, but since this is a safety-oriented forum, I won't advise that. If your measurements are true, you should be okay with the caveats above.Wood should be tested when at room temp, not outside unless it's summer. 23-25% is a bit damp. If you can bring it into the house for a few days before burning that may help.
You will need to watch things a little more carefully and watch for signs of creosote buildup such as blackened glass, etc. You may not be able to turn the air down as much or as soon as you would with dryer wood. If possible, take a look down the chimney with a flashlight to look for creosote a couple of times this year. You may want to invest in a "Sooteater" or similar cleaning tool also.
What species wood is this?
Be sure you are measuring the inside face of a fresh split like Jake said.
I'm not sure, i've reached out to the company we purchased it from (http://www.northatlanticfirewood.com/) and they said "Our wood is a mix of hard woods including oak, maple, and ash".
I didn't re-split, but I took a reading on some pieces that have been inside for 4-5 days and it measured 13-15% with my General 2-pin moisture reader
Essential. Wood will dry on the outside much quicker than it will dry at the interior core. A lot of "seasoned" wood is from logs that have been down for a while, but only split the week before delivery. That wood most likely is still unseasoned and damp inside. Bring some of the wood indoors for a day, then resplit and test again on the freshly exposed surface of the wood.It's kinda important to resplit and test the wood on the inside of that resplit to get a more accurate moisture meter result.
