Wood Stove Insert DIY
gobblerpah Posted By gobblerpah, Feb 18, 2010 at 3:44 PM
Thread Status:
  1. gobblerpah
    gobblerpah
    New Member 2.
    NULL
    Feb 18, 2010
    3
    0
    Loc:
    Middle GA
    I have purchased a Appalachian Trailmaster 4N1 Catalytic Stove. It is used I would say about 10-15 yrs old. It is in good shape however it needs a little TLC. ie. a new door gasket and some new bricks. I want to install it in a factory built fireplace and was wondering if I could use the existing 8"flue from the fireplace or do I have to line the existing flue with
    stainless or some other insert specific flue liner? My existing fireplace was installed in 1999 and the flue appears to go all the way to the top of the chimmney. Also, my fireplace needs about 2" more height but I think I can trim some height off the bottom as I have about 6" of open space between the unit and the top of the hearth. Is trimming not an option or okay? Also can I remove the faux brick panels on the sides and rear to accomodate installation. Any help would be appreciated. Thank you.
  2. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,868
    8,624
    Loc:
    South Puget Sound, WA
    Do you have the manual for the Appalachian insert? The stove must be tested and approved as a prefab insert. The prefab flue is not approved for woodstove high temp use. It would require a liner which means 6 or 7". Generally it's not a good idea to disassemble the prefab parts to fit in the stove. A picture of the current fireplace would help to figure out options. Do you know what the make and model is?
  3. gobblerpah
    gobblerpah
    New Member 2.
    NULL
    Feb 18, 2010
    3
    0
    Loc:
    Middle GA
    Here are some pics. The fireplace is a Martin Industries SF36 model.
    The Appalachian Trailmaster is approved for Prefab install as well as mobile home freestanding.
  4. Wood Heat Stoves
    Wood Heat Stoves
    Minister of Fire 2.
    NULL
    Jun 12, 2009
    1,905
    14
    Loc:
    Nevada City, California
    generally you cant remove zc firebricks before wood insert install
    also, ul177 listing on existing vent? if not, full reline with insulation for code install typically
Thread Status:
