Work for this Weekend
thewoodlands
16,693
In The Woods
Have some more cherry that I should get to Saturday or Sunday, should be able to winch some of this down.
Zap
These don't worry nearly as much as ones that have their tops hung up.
smokinjay said:
Zap
Looks like fun! Heres a great way to bring down the leaner
https://www.hearth.com/econtent/index.php/forums/viewthread/48329/
I'm going to v the top 1/3 way through at about chest high and then cut from the bottom up. That v will stop the top from pinching and should drop to the ground and then I will winch the rest down.
Zap
zapny said:
smokinjay said:
Zap
Zap
there is a lot of weight there chest high cutting is not good.imo
smokinjay said:
zapny said:
smokinjay said:
Zap
Zap
Ok how about waist high?
zap
zapny said:
smokinjay said:
zapny said:
smokinjay said:
Zap
Zap
zap
much better, what size bar you running on that 390?
zapny said:
smokinjay said:
Zap
Zap
Zap, if you cut 16" length firewood, then cut the tree into 4' lengths. In that leaner that should about get you to waist height which is much better than trying to cut up higher than the waist.
Also, there should be no need to cut a V in the top. Just cut half way or a little more and then cut from the bottom and it should do you well.
Backwoods Savage said:
zapny said:
smokinjay said:
Zap
Zap
Thanks Sav, I usually don't cut the v but use it once in a while. Had one pinch at the top after that I used the v a couple times. Last weekend when I cut the smaller cherry that was in the same position I didn't use the v. The wood for next heating season I'm cutting 15 inches for better N/S loading in the Liberty.
Some of the softwood I'm cutting for the shoulder season will be 18 inches.
Zap
Zap, I like those which when you finish the cut still stays leaning. Then set the saw down and a gentle push and down it comes....going away from you. I've had some that I've used my foot to kick and even some I beat with a maul. Just whatever the occasion requires.
I like the beat it with the maul, just got new boots from Labonville.
http://www.labonville.com/shop/pc/viewPrd.asp?idproduct=80&idcategory=243
zap
what size bar on the 390?
I run the 20 inch on the 390 but have the 16 and 18 inch also. The 310 has the 18 on it for this weekend.
zap
zap
"perfect" set up for the woods.......I always seem to get the urban jungle with crap everywhere(house garage telephone poles and driveways)lol
