Montpelier is making surrounding brick hot!
Jnaugh
3
Indianapolis
Good afternoon, first time insert owner here. When I get a hot fire going in my Montpelier insert, the brick of the original masonry fireplace above the insert might get up to a hundred and eighty degrees. Is this normal? One of my buddies who has a slightly different insert says that his never get that hot. Any help?
I would expect it to be at least that hot when up and running. Each install is different as well as each insert.
Flush inserts may get the brick above the insert hotter than inserts that protrude a bit out onto the hearth. Also, some inserts have a convective top that acts like a bit like a heat shield for the above brick and mantel.
Thanks for responses folks. makes me feel better about it. I was a bit concerned but then I was thinking, those brick get fired at several thousand degrees. a couple hundred probably won't hurt. thanks again.
Make sure that the mantel clearances are safely met or exceeded.
Reactions: Fod01
Those bricks are about as hot as the water from your hot tap. I think it'll be ok!;)
!! Our water is at 130F. 180F water is scalding hot.
I wouldn't worry. Perhaps your stove fits a bit tighter than your friend's, or the surround is transmitting more heat to the brick. You could pull the stove out a small bit to create a gap between the brick/surround. I have one.
It's supposed to be colder this weekend. I'll measure my temps after I stare at the fire for a while.
How hot are you running the stove, and how do you measure?
Gabe
Gabe
Thanks Gabe
I have what I think is a hot fire. I measure the door frame with infrared at around 350-400 degrees. I don't know if that qualifies as a smokin' hot fire or not but it sure seems hot.
Thanks everybody for your replies.
Yep, 350-400 on the door is a nice hot fire [emoji106]
