Now I’m gonna worry about that!developed a pinhole leak
Well, in my case a leak would only result in ruined drywall in the garage. There are plenty of worse places for a pipe leak. I guess I’ll just be on the lookout over the next week.
Gotta be careful tho....that technique can loosen solder joints if copper n left on too long!That's interesting. No exposed flame. Less chance of fire?
I'll say, especially if the alternative is the outhouse.Extended cold of -10F and much lower into the -30'sF and still lower, plus little snow cover does put septic systems at risk of freeze up. Kind of *hitty when that happens.
OP you need to get a therm-guard... The guy who invented it, posts on this site. I just bought 2 of them last week after frozen and broken pipes two weeks in a row. I installed it in 5 mins, hooks right into thermostat. Runs your baseboard for a set time and interval regardless of the thermostat temp. I do 5 minutes every 2 hours, the guy who invented it in Montana does 5 minutes every 3 hours. I'm being cautious as I don't want to deal with any more frozen pipes. For $60 something dollar with the 10% coupon on hearth.com it's the best damn insurance policy I've ever bought...
http://www.bearmountaindesign.com/
I set my thermostat for 62-64 degree's, wood stove runs all day, thermostat says 68-70. After I fall asleep, maybe heat kicks in 6-8 hours later in the middle of the night but good old thermo-gaurd circulates my pipes every 2 hours. CAN'T BEAT IT, I even ordered a second one for my other zone but have yet to need it.
This is awesome. I have three zones, one is in the living room where the stove is, so will need one each for the other zones. We are actually holding off a little on the stove due to chance of frozen pipes.OP you need to get a therm-guard... The guy who invented it, posts on this site. I just bought 2 of them last week after frozen and broken pipes two weeks in a row. I installed it in 5 mins, hooks right into thermostat. Runs your baseboard for a set time and interval regardless of the thermostat temp. I do 5 minutes every 2 hours, the guy who invented it in Montana does 5 minutes every 3 hours. I'm being cautious as I don't want to deal with any more frozen pipes. For $60 something dollar with the 10% coupon on hearth.com it's the best damn insurance policy I've ever bought...
Well, it’s been unusually cold in CT since Xmas. My insert is in our family room, which is over our garage. The room is about 400 square feet with vaulted ceilings. I’ve been using the stove to heat the room for the past week.
Well, this morning it was back to work for me, and my wife isn’t comfortable feeding the stove. So I set the thermostat with just coals left in the stove and went to work. When I came home, the room was chilly. I turned up the heat and nothing.
The good news is that the zone with the frozen pipes exclusively feeds the one room. The rest of my house has heat. Plumber is coming in the morning, and I’m hoping the pipes didn’t split. Won’t know until they’re thawed.
Maybe this will be of help to others... just because your stove is keeping your house at 80 degrees doesn’t mean that baseboard heat can be turned off in subzero temps. The outside walls get cold enough to freeze the pipes, which never occurred to me.
Wish me luck!
Anything that causes injury to firefighters? No contest. I hope your guys over there recover and can return to work.Which is worse? Freezing, burst pipes or this? Debatable perhaps?
https://www.boston.com/news/local-n...-caused-by-man-trying-to-thaw-pipe-with-flame
(From last week . . . the firefighters are more or less OK by the way.)
