Acting up 2007 model
woodsman23
1,364
western southern tier of NYS
I have an 07 Afton Bay pellet stove and the blower motor will not shut off after the stove cools I should have said the combustion motor will not shut off It just keeps running any ideas what this could be or is there a switch on missing and where is it located thank you
The likely culprit is the Proof of Fire snap switch. On Afton Bay, it's mounted right on the combustion blower housing. An easy way to test it is to disconnect it after the stove shuts down and cools off, but the blowers are still running. If the blowers stop when you pull the wire off, the switch is bad.
I tried and succeeded in pulling off the wire and it still continues to run is this a control board good gracious I hope not.
Reactions: RyanMcD
