1 1/4" pex fittings supplier?
colson04
26
Delton, Michigan
)From the recommendations of the forum, I decided to upsize my supply line to the house from 1 inch to 1.25" pex. I ordered the tubing from Menards, only to find they have limited selection of 1.25" pex fittings. So, where do you guys get fittings from for 1.25" pex?
I found outdoor furnace supply, are there any others?
Sent from my SCH-I545 using Tapatalk
Looking through supply house, I see they don't have 1.25" pex crimp connectors (what I am familiar with), but they do have 1.25" tectite /sharkbite fittings.
Anyone use these in their hydronic system? I see they are rated at 200 deg F, I plan on running my OWB at 180 deg F like I had previously.
I used barbed fittings like this. [Hearth.com] 1 1/4"  pex fittings supplier?
I used shark bites on my OPB (pellet boiler by CB) They did just fine for 4 years, and the guy I sold it to is still using some of the same fittings. I had them out on the inlet and supply on the boiler, as well as inside on the HX.
I ran 180* water.
Here is what you want.
(broken link removed to http://www.badger-pipe.com/cgi-bin/commerce.cgi?search=action&category=PFT4)
Not sure if you want to buy the crimp tool. $240!!
Sent from my SM-G900V using Tapatalk
I used the badger fittings. Or ones found on ebay. Then put two hose clamps on each one ( bulk on ebay), they have held for 10 years no problem. Then you don't have to buy crimp tool.
I checked out their site, they have a 1.25" crimp tool for $66. Their fittings prices are way more reasonable than everyone else. Thanks for sharing
I need to check ebay more often, I've gotten away from using them much anymore
I ended up getting my fittings and crimp tool off ebay. Crimp tool is made by a guy here in Michigan, fittings and rings ce from Badger supply out of Wisconsin. Prices reasonable, tool is excellent quality and fittings fit nice and snug with the pipe. Easy to use and no leaks o the pex fittings . I did have a leak on a threaded adapter, but I took it apart, reapplied tpfe paste and reassembled and that fixed the leak.
Reactions: Buzz Saw
