I am usually of the oppinion to do it right
If it costs a little more and is a little more work, but makes the install correct - do it
That being said - I am considering if I should install an outside air kit for my T6.
The stove will be in a lower level that is above grade on 2 sides. The stove is against a wall that is backfilled with dirt outside. So I would need to drop out the bottom of the stove and run 15 feet horizontal across the floor - then drill out thru the concrete wall to open air.
Will the length of pipe restrict the air flow and defeat the purpose?
That being said - anybody that wants to throw out an oppinion - I am all ears.
Thanks in advance
Thanks in advance
