1979 hs tarm
8nrider
118
new hampshire
recently got a 1979 hs tarm mb 55. i was hoping to use it on a chimney with a 8" round flue but after reading specs discovered they recommend a 8 x 12. i have used the chimney and it had good draft . my biggest concern is that they recommend having only one 90 elbow or two 45's. in the pipe. ???? ii need to use 2 45's. i do realize the importance of seasoned wood. been using wood for heat for at least 30 + years, but never had a wood boiler. any feed back would be appreciated. thank you.
8" round will be fine.
Reason for the 8 x 12 suggestions is that most square 8 tiles run 7" or smaller ID, so it starts to get tight.
That is a decent boiler....
Use the shortest route and least possible turning radius to get to the chimney - 2 45's are likely to work better than 90's.....gradual turns allow smoke to flow easier.
thanks craig good moral support. i was wondering when they started using round tile ? i've torn down alot of old chimneys but never one w a round flue tile.
i find it impossible to use just 1 90 inless it is a topflued stove which the tarm is not
Round tile is best - I have seen it used in high end homes in Philly, Boston, NYC, etc......
The rumor goes that the only reason ALL chimneys do not have round tiles.....is that they do not stack and ship well.
Strange, eh?
They also cost more and 5 or 6" fit loose in lifts.Would need to be packed with vermiculite. You can put 3 6" in an expanded lift though.
Will
