Hi,
I recently purchased an Osburn insert built in 1989, but no model number on the tag.
It is in very good condition and cleaning and painting. It a solid cast iron door brass plated with a two speed fan box mounted on the front. It will handle a 16 inch log. Seems very similar to a Osburn 1100.
The issue is we cannot get it to burn well, with having the door slightly open. It has a air jacket around the insert with a blower. The draft control is on the side with a sliding metal gate underneath.
The insert didn't come with any legs, so it's sitting flush on the fireplace floor. There are nuts welded on the back sides that appear to be for leveling. It seems the insert simply isn't getting enough air. Does the bottom of the insert need to be raised on the fireplace floor to supply enough draft air? If so, how much. It is a very small fireplace with only about an 1.5 inches to spare.
Thanks,
Ken
Thanks,
Ken
