1989 Pacific Energy Spectrum Window seal size?
Oct 24, 2024
41
Oregon
Hi all,
I'm in a pickle. I've got an 72,000ish serialed Pacific Energy Spectrum manufactured in Oct. of 1989. She turns 35 this month! The seal for the ceramic glass is in really bad condition. I've called the three closest Pacific Energy dealers and they told me to bring it in, but they're, literally a hundred miles away. The on there now is kind of like a sock that goes around the glass. I see on Amazon there's generic, sticky, cut to fit window seal tape that sticks to both sides of the glass, but I don't know what thickness to get? My seal is basically disintegrated, so I don't trust my measurements. Oh, and there's no part number. The glass part number says "C/W Seal."
I got cold toddlers, so any help is appreciated!
I would try some 3/4” or 1” tape gasket. The adhesive backing will allow you to to center the adhesive side on the edge of the glass, make one complete turn around the perimeter, trim the ends squarely to meet & then adhere the tape to both the inner & outer sides of the glass. It generally comes in rolls & most hearth shops will have it. Good luck!
Daksy,
Thank you for your response! Good to know the width! Do you have any idea on the thickness of the gasket? 1/8", 1/4", etc.
- GDOOC
P.S. Is this the right forum or should I be in the Pacific Energy? This one said it was for stoves prior to 1993 and mine's a 1989.
I ended up going to a local wood stove shop and getting some and making it work. The worker wasn't sure of the width and neither of us had a tape measure on hand. I meant to measure it to post on here, but forgot. 1/8" seems reasonable.
