1st Cleaning Chimney with Fireplace Insert (Enviro 1700)
Nov 23, 2018
46
06070
Hi Folks - I need to schedule the first chimney cleaning after installing an Enviro 1700 insert. I plan to have a local service do this, chimney is really tall and I don't have the equipment, ladder, experience, etc.
I need help to understand exactly what the process involves. Do they need to pull the stove out to completely clean it? Or can this be done with the unit in place? The interior is baffled so I don't know how they will collect the soot? Etc.
Any guidance appreciated.
Thanks
Thanks
They will probably pull the baffle out and clean up through the stove. They absolutely will not pull the stove
So there is no need to go on the roof?
Generally no. But if it was me for a new customer I would go up to inspect everything. I would also either pull the surround or move the stove enough to check the connection, check for a blockoff plate etc
Come on over Bholler!
Second Question - I plan to have a damper block off plate installed - any idea on a cost estimate?
I would say $300 to $400 to put one in after install
