First, i have a Harman P61A and have owned it since 2008. I clean it regularly, full cleaning every 4-5 weeks during the burn season. I run about 4 tons through it each year.
I fired up my stove last night and noticed a noise coming from my stove. At first I thought it was my distribution blower but that is almost new-just about 2 years old. I believe its my auger but its not really a squeal, its almost a humming and grinding noise as if the auger is rubbing against the auger tube.
So today I shut the stove down and gave it a good cleaning. I scraped out the auger tube, cleaned all the ash and fines box. I even added a little graphite powder into the pellets where they feed into the burn pot-hoping to lube the auger.
I really don't want to pull the auger motor so close to the end of the season but am i missing anything else?
Separate from the auger issue, i turned the stove to the off position this morning around 10 and left the house knowing i needed to do a cleaning this afternoon. I returned around 3 to find that my stove was still running, basically keeping the room at the same temp from when i left. In order to get the stove to shut down, i had to scrape the pellets from the burn pot and let the fire die that way.
Any thoughts on these issues?
Thanks!
Thanks!
