I have two woodstoves that I would like to vent together. I will only use one at a time.
They have an independent chimney. It is clay pipe lined. Currently I’m only running the fisher baby bear into the chimney at a 45’ angle with a 90’ into the chimney.
I’d like to replace the 90’ coming out of the brick with with a T … the. Run the baby bear
Straight into the bottom of the T and then attach the small cooking stove with a 90 into the other arm of the T.
Can I do this safely if I only use one stove at a time? Or is it possible to even use both stoves at a time?
![[Hearth.com] 2 small wood stoves into 1 pipe [Hearth.com] 2 small wood stoves into 1 pipe](https://www.hearth.com/talk/data/attachments/286/286904-8a774c421cb7358bfb1968f3521a2242.jpg?hash=j2jYcJUnv6)
![[Hearth.com] 2 small wood stoves into 1 pipe [Hearth.com] 2 small wood stoves into 1 pipe](https://www.hearth.com/talk/data/attachments/286/286906-002a1be5322b6bbc1279d23c26990133.jpg?hash=cn_CHDDU0s)
