this is a 2008 accentra insert. the feed adjuster over the last couple of years has been an issue. as an example, i can set the feed rate to 4 and the auger will run for 30 seconds, but then i could turn the feed rate down to 2 and it might run for 35 seconds. its like the run times can be all over the place. so i finanlly purchased a new control board. the instructions with the new board show that dipswitches 3,5 and 6 should be ON, all others off. when i turned the stove on, i got three blinks on the panel. which seems to be an issue with the ESP. i pulled the probe out and cleaned it, although it did not appear dirty. that did not help. each time i turned the stove on, i got the three blinks. so i went back to the dipswitches and compared them to the original panel. the original panel had dipswitches 1,2,3 on, 4,5,6,7,8 off.
this got rid of the esp error and the stove is back running again. however...the feed adjuster seems to still be doing the same thing. right now, if i set it to 4, the auger runs for roughly 23 seconds. if i turn it down to 2, it runs for about 26 seconsds. i've turned it up to 6 and it only runs for a few seconds, i think less than 10. if i turn the adjuster to 'test', where i believe that should make it run for a full minute, is only running for 7 seconds. so i'm stumped as to why its doing this. anyone else seen this happen and have any ideas for me? thanks in advance.. Brian
