After 8 years the Leyden Auger is making some serious groaning noise. Reading through some "old" posts here: https://www.hearth.com/talk/threads/lopi-leyden-auger-removal.65095/ it appears that the problem is the lower auger brass bushing (binding, corroded, worn out etc.). I loosened the Auger Motor locking collar so it was not attached to the auger and the motor spins fine and quiet. The groan is coming from where the lower auger goes through that bushing to attach to the motor.
In that old thread Wood Heat Stoves says to just replace the Lower Auger Bearing Plate. The bearing (called it an "oilett"?) is part of the plate. Also in that thread is says Travis Ind. tech said to just clean the auger end and that bushing with some fine steel wool.
I am going to the dealer to order that plate with the bushing and will replace it. Will also clean one on there now. A few questions for anyone that has done this on a Leyden or Avalon or similar:
1. Does the motor just slide out of the motor stop bracket? Looks like it just sits in there and there are rubber bumpers (black circle below arrow) on each side. I can't remove that bracket ahead of time as it is bolted from the top of the auger bearing plate. When I loosed the auger locking collar (Allen bolt) the motor did slide up and down a bit.
2. Is that a gasket underneath the bearing plate or maybe high temp silicone (the red stuff)?
3. Any other advice?
Thanks!
![[Hearth.com] 2008 Leyden Auger Groan [Hearth.com] 2008 Leyden Auger Groan](https://www.hearth.com/talk/data/attachments/164/164495-a3c550b516f67ceac3f3dec7d4ff4ef9.jpg?hash=3mlknEseU7)
Thanks!
