Thank you ChrisPool & Spa Outlet
160 Galley Road Canonsburg Pennsylvania
15317 US
Telephone: 724-873-7665
They have two stores, so they may have stock. Don't hesitate to use our look up option on the website and try other areas as well.
Thank you.
15317 US
Thank you.
Yes, that's what's on my business card anyway. Thank you for the compliemnts regarding your stove. I hope you enjoy it for many decades.
Chris
It lit up just like that, went right into an active state on the cat, stayed lit, and the burn control is excellent.
What do you mean by, "a third of the way into active"? I understood that just as soon as the inactive/active line is crossed it is time to engage.
Huh. Really? I thought you had to wait until everything was all lit up. In lieu of waiting for all of the logs to catch, I waited until the cat thermometer was about a third of the way up before engaging the cat- but not all of the wood was charred at that point.
I hope I didn't injure anything by waiting. The stove didn't do anything weird. (Please don't ask me to define what "weird" might be. The stove didn't catch the house on fire or scare the dog or make waffles or anything.)
I'm still learning; be gentle with me.![]()
You did everything fine.
You could close the by-pass sooner if you wanted to as long as you leave the air(t-stat) up till the wood is charred good so that the cat has plenty of food and won't die..lol.
You did good!
Just so you guys know.
I have seen from a reload ,or especially a cold start the cat temp be halfway and the cat still not active at all.
The cat probe will pick up the stove top temp not just the temp from the end of the probe because the coil is right on the stove top.
That's weird. If the cat temp is active and climbing then your cat is active. You do realize that it doesn't have to glow to be working right? What made you think it was not active?
If you look at his avatar, you'll see that he's a pro fisherman.Are you THE Blaze King VP?
That's how I run my cat stoves; Rake the coals forward and get fire in the front of the stove to get the cat and stove up to temp, the light the cat, cut the air and let the burn work its way back through the load. A top-down start with the small kindling stuff in the top/front of the load will get even less wood burning at the beginning (and produce less start-up smoke,) but will put heat in the top of the stove to get the cat up to temp quicker. Less of the load will be gassing and you should be able to run the load at a very low output.In lieu of waiting for all of the logs to catch, I waited until the cat thermometer was about a third of the way up before engaging the cat- but not all of the wood was charred at that point.
OK, this whole "cat is active, cat is not active, cat never fired off, thermometer is indicating temperature of stove top, cat may not be active even if the thermometer says it is" thing is confusing.
I do NOT want to over think this. One of the selling points of the BK stove is simplicity of operation, less fiddling with it. You don't have to touch it so much. After cleaning and loading and tearing down a pellet stove on a regular to daily basis the whole simple wood burner is a relief to me.
Last night the cat glowed at one point but then the glow subsided. The cat was glowing not long after the whole start up routine, when the stove was probably at its hottest overall (even though I started it a lot slower last night.) Once established, the stove was at a nice, low burn, not running us out of the house.
As our stove shop owner said, the stove was "cooking" the wood rather than burning it up quickly. Isn't that part of the reason why we buy Blaze King stoves? This long, slow, efficient, fuel preserving burn?
So later, when the cat wasn't visibly glowing, the cat thermometer was still way into the active range and the flames in the upper part of the fire box near the cat would intermittently appear and disappear. I took this as the cat in operation, burning off the products of combustion in the fire box.
We went to bed with the stove burning just like this. When we awoke later this morning, the wood in the stove was almost completely reduced to embers and large chunks, which are still hot. The stove is still quite warm and radiating. The cat thermometer is in the inactive range but we don't care. We do not need any more heat in the house at this moment and we aren't reloading the stove.
Honestly, I don't want to baby sit the cat. I want to treat it right, light the stove properly, burn it according to the manual, and go on about my life. I'll clean the cat when I need to clean the cat and I'll replace it when it's worn out. Otherwise I just want the stove and the cat to do what they are supposed to do without a lot of fiddling. Is that unrealistic?
How on earth, besides the thermometer, are you guys judging whether or not the catalytic converter is active and engaged? Are you relying solely on whether the cat is glowing or not? Is that a true indicator of cat activity or absence of cat activity?
Well said.That's what I was afraid of. If the cat gauge says it's active, it's active. Don't worry about the glow, that is not an indication of activity. Trust your instruments. You are doing a great job running that stove becasun.
Also understand that we are stove nerds, and really dwell on the details and theories. When you burn a bk you have to make problems because the dang stoves are too boring otherwise.
(Pity Mr. Sunshine. Light a candle to the God of Husbands on his behalf.)
Guess I'm getting to deep into it but she did fine..hard to mess it up really.
It's my fault, truly.
