Just checked again, cat thermometer is at 12 oclock. Stove top temp is 280 *f so it's dropping. Cat is active, no smoke coming out the chimney it's just not staying as hot as others seem to be getting theirs at similar settings.
Shane, My thermometer is above the cat on the steel body of the stove. Keep in mind the Princess and King wear no shroud. Well, other than side and rear shields on some.
Chimney length and materials used affect draft. Draft effects stove opeating temps. Thermostats and settings will vary as much as the Temps themselves die to many variations (draft, fuel type, moisture content..etc)Just checked again, cat thermometer is at 12 oclock. Stove top temp is 280 *f so it's dropping. Cat is active, no smoke coming out the chimney it's just not staying as hot as others seem to be getting theirs at similar settings.
Yeah, I wondered if they meant load it N/S from left to right vs.. left/right as in load it E/W.. I've kinda done both, since I use a welder glove it's no biggie getting splits to the back.
EDIT: Well on going back and reading it again, sounds like they do mean E/W.. or not?
Operating instructions, page 23.
#7: When nearly all the wood in the firebox is burning , finish loading the stove. Lay the wood left to right, as far to the back of the stove as possible. After the loading door is closed and the catalytic thermometer is in the active zone, close the bypass door.
I run north south too and on occasion have been guilty of trying to get a split that is just a little too long to fit pounded in to the point where it just doesn't touch the glass. I've thought about it expanding and nervously sat by the stove watching it burn down with out any issue. I don't recommend it... But I don't think they expand much either.The manual for the princess says to load it left to right.. I've seen some folks loading front to back. Does front/back help to keep the glass cleaner? Is there a reason for going one way versus the other, other than with front/back if your splits are too long they can expand and push on the glass?
I don't have a Stovetop Thermo, but I do use an IR point and shoot..Does anyone here have a stove top thermometer on an Ashford? and if so what temps are you averaging?
That makes sense then. I did ask in my previous post if it was on the shroud or not. Didn't realize the king and princess had no shroud. Anyway I shouldn't read into it too much. I know everyone has a different situation and I'm heating my house fine on 2.5 and on average a full load is lasting about 24 hours before a reload.
I think if I were telling someone how to put wood in a fireplace, I'd also say "Lay the wood left to right, as far to the back as possible"..
We installed our BK Princess Ultra Saturday 11/15, it has been running 24/7 since then. Our house is a 1700 sq ft 2 story farm house built in 1900 that is well insulated and has new windows (27x72 lots of them!) with 9ft ceilings down stairs. I have opened the transoms above the doors to other rooms and it has done wonders to warm them up. We burn mainly white oak (we get cut offs and scraps for free), some cherry, and whatever else is free. We have been loading our stove 2-3 times a day on a setting of 1.5-2, this keeps the main level 74-80. My stove top temps range from 475-550 with the cat glowing a dull red and occasionally some secondary flames coming out of it. The chimney produces more of a vapor than smoke except when we reload the stove. My question is am I doing this right ? Are my stove top temps ok with the relative heat setting ? I think this thing is better than sliced bread and pockets but I'm willing to learn anything I can to improve it. Thank you in advance for your help.
I have only tested the outside of the wood with a moisture meter and it reads about %10. We just moved in and I can't find my axe to split a piece of wood right now, my nephew borrowed my splitter and it's not back yet. We load the stove pretty tight at bed time and have always had a bed of coals to work with in the morning. The stove has truly had one fire, the first one and it's still going. I have played with E/W & N/S loading. I get better burn times with N/S if I have enough short wood, our last house had an add on wood furnace that took long wood but most of the oak I get is short anyway. I will dig for my axe or go buy a new one and post the results. 80% of what we burn is the white oak. There is a company that makes the slats for whiskey barrels by a friend of mines house. I take my dump trailer there and the scraps are free for the taking. I tip the loader drivers $20 to load my trailer from the scrap bins, that way everything I get has the bark removed.Have you tested the moisture content of the wood with a moisture meter? How dry is it? And how full and tight are you loading the stove with your firewood?
Sorry I guess I need to clarify. We only load it as full as we can for an overnight burn. In the morning I will pull the unburned pieces of wood to the center with the coals and add some to the top of that. I've just noticed that towards the end of a full load of wood the stove top gage is towards the "inactive" range. I try to keep it a fingers width to half way above that mark. I loaded in a few splits of wood this morning and my gage is at about the 10 o clock position with a 550 surface temp. I did not load it full though, just a few pieces to bring the gage back up. Will it shorten the life of the cat if it goes into the inactive range ?What Rossco said. Are you loading it full?
I'm not sure I could even burn through three loads a day in the Princess if I tried.
Once the stove begins to naturally cool toward the end of the burn cycle it is fine to let the cat go inactive. Just flip the bypass and reload when needed.
