Let me start this by saying that I bought all of my GTP's at a good discount, and well before the current price increase that has them at $350/ton. I paid WAY less then that, so to me they are a bargain.
I tested a bunch of brands last year and the GTP's were one of the hottest and a little better then average on ash, so I figured they would be a safe bet again. I think they've actually improved for 2014! Hottest pellet I've tested to date this year. I'm using my new stove for testing this year (Englander EP) so the numbers from last year can't be directly compared to this year. Here is my test results for 2014 so far:
Green Supreme (Jaffrey, NH plant, leftovers from 2013)- 228.5 degrees F
Inferno Gold- 244 degrees F
Lacrete's* (moisture damaged bag)- 262 degrees F
Green Team Platinum- 274 degrees F
So GTP's were already top, but this morning I tested it again and got 304 degrees F They also appear to have less ash content, possibly the best I've seen yet this year.
Testing method is by Thermapen held at the center of the air outlet, not touching any metal, just measuring the air that is actually being blown into the room. Clean stove before each new brand to ensure equal conditions. Heat is measured twice (spaced apart) and averaged for more accurate data.
* I have only tested moisture damaged bags of Lacrete's so far, I will retest with normal bags later and I expect better results. Every one's stove and install are different, so my results may vary from yours, but are consistent among themselves.
