Go for it!View attachment 262955View attachment 262956
can i use this stuff on the bypass lever? might be a silly question, but this is not in my wheelhouse of knowledge. clearly worried that it has petroleum-based product in it.
The cat thermo are NOT scientific instruments. In fact, if someone (all you engineers) designed an accurate thermometer, you can own the market. Within a couple of days, the activity will reduce. The thermostat control peak temps.I would be concerned myself. If I'm recalling correctly, 1,600°F is the temperature at which the coating will peel off the cat. I thought that the 'too hot' area of the cat probe thermometer was to be avoided for this reason. @BKVP please clarify. Is it ok for the cat temp probe to be pegged like that every so often, just not for very long periods of time?
Auber AT100 comes to mind.The cat thermo are NOT scientific instruments. In fact, if someone (all you engineers) designed an accurate thermometer, you can own the market. Within a couple of days, the activity will reduce. The thermostat control peak temps.
I wolda agreed with you for the last couple of years..Auber AT100 comes to mind.
I believe the actual meter reads ok, the probes are the problem (china made). I have burnt through few of them on my VC yet never went over 1800*F. The probe is supposed to be good to 2000. All three went wonky in terms of temps and i knew the tips were no longer good.I wolda agreed with you for the last couple of years..
But my Auber went whacky, so I ordered a new probe from them, new one was about 300 deg. Different from the other new one I had..
Several calls to their # that rings in some 3rd world country left me pretty pissed off..
So I went back to the BK probe for the King, and the Princess..
First overnight burn in the new Princess. Started the stove around 4:00pm, had a nice bed of coals by 6:30, loaded it to about 3/4 capacity with dry oak slab wood. About 10-12 minutes to a very good burning fire and started turning thermo down to find low and slow burn setting. By 8pm, no visible flame, lots of cat glow, cat indicator just past the end of active zone. It stayed that way all night( had to get up and check on it a few times). 5:00 am, same thing. Opened the bypass and thermo, gave it a few minutes, stirred up the coals, repeat procedure. This could be the beginning of a great relationship. LOL
Couple of years ago, while splitting i decided to split a bunch of 12x12” (approx) of hard maple. Next season i will try burning it in the BK.
I have some huge knotty pieces of maple that have been seasoning for 3 yrs now. they split in all different shapes and sizes twisting and turning. I have quite a few that I know are going to be one log loads on hot coals. I'm very anxious to see how it goes.If you have those big dogs you’ll need more little guys to fill around him to get maximum fuel charge. Much bigger than 6” and I have a hard time getting two rows in. A variety of sizes helps but on average, bigger dry splits win.
Thats how you test the window gasket, you see if you can wiggle it, if you have no play in it then you should be good to go.I have a question about the door glass gasket on the Ashford 30. Is there just a rope type gasket or is there some sort of epoxy as well? The glass seems very solid. No play at all. The reason I'm asking is because I'm afraid I might of gotten carried away cleaning the glass edges and I can feel a slight groove or lip along the bottom edge between the glass and what I assume is a U shape holder. Its possible that it should be like that all the way around and it's just caked with creosote. Something I should be worried about?
How are you measuring these? In the past I’ve always split to “palm size” Er.. 4 inches? Basically I can grab it by the end with one hand and handle it.
help me out with the proper measure technique? I’m not worried my splits are gonna be too small for the king this year.
secondly, question for you and the class, what moisture content does the BK like? I just went through my stacks. I’m testing between 14 and 22 percent on a fresh split face depending on where it is in the pile and how big the split is
Thanks dudes.
The stove goes in today! Installer will be here shortly. I’ll post some pics in the hearth build thread I made awhile back.
Now, I’m chomping at the bit to burn. Just looked at the forecast. Won’t be firing up for some time. Still going to be around 70-75 here in NW Oregon
Hi. I'm looking for a wood stove to heat a three season room in Canada. It will often be fired up when the room is at or just below freezing. I'm considering the Supreme NOVO 24 but the Blaze King 24.1 has caught my eye. Any reason to go with the BK unit over the Supreme?
supremem.com
That's their new boxer stove.
Boxer 24 - Blaze King
The BX24 Boxer is very clean and efficient. Performance is balanced to deliver a greater amount of radiant heat through the large glass door. The BX24 Pedestal Base is approved for wood storage within the cavity below the appliance.www.blazeking.com
Vs. a very similar looking noncat
Supreme - NOVO 24 | Freestanding Stove
supremem.com
Since this is a BK thread I can pick the boxer for you but that's mostly since I've never heard of anybody using the supreme brand.
You must really like that look. Have you considered the BK chinook? It is more common and seems to be a great heater.
Canada is a vast track of land! Some parts are relatively warm in the winter and other parts are damn cold.Hi. I'm looking for a wood stove to heat a three season room in Canada. It will often be fired up when the room is at or just below freezing. I'm considering the Supreme NOVO 24 but the Blaze King 24.1 has caught my eye. Any reason to go with the BK unit over the Supreme?
Indeed! I'm in southern Ontario so I think the sun room will be below freezing sometimes.Canada is a vast track of land! Some parts are relatively warm in the winter and other parts are damn cold.
Its this reason why I dont think a BK stove is the right pick here, you want fast blast heat, like 70k btu's per hour stuff with a 2.5 cu ft fire box, since the room will be having some cold starts, I nice drolet would be a good fit here, without breaking the bank.Indeed! I'm in southern Ontario so I think the sun room will be below freezing sometimes.
Is there some kind of BTU calculator that takes into account starting temperature?
Oh I see. Cat stoves burn longer and slower so I want a non-cat stove. The supreme NOVO 18/24 aren't cat and have BTU of 60000-75000 which seems potentially appropriate?Its this reason why I dont think a BK stove is the right pick here, you want fast blast heat, like 70k btu's per hour stuff with a 2.5 cu ft fire box, since the room will be having some cold starts, I nice drolet would be a good fit here, without breaking the bank.
