How much ash?
I’m at about 3 to 4 inches right now ish..
The loop on the ash plug keeps getting in the way. Doug fir doesn’t make much ash!
How much ash?
I wish Hedge was all I had to burn! Talk about good fortune. I am a few rows of counties to far north to enjoy that wood. I've never heard of anybody having a issue with Hedge or any other wood variety in a BK.Would hedge, or osage orange, burn too hot for a blaze king? I've never been around a catalytic stove but I'm looking at a BK and hedge is generally what I burn.
All the King represents is a larger fuel tank! And, you will pay dearly for an 8" chimney system compared to the Princess 6" system.Question before it’s too late, I feel like I will be happy with the princess as far as burn time and heating but I’m curious if there would still be an advantage to buy the king. I guess a concern for me would be burning at a lower setting more often might cause more issues than advantages . Think I still have a minute to change if there’s a good argument for the king. Thanks ahead for input
I’ve been running both for the last couple of years, King in the house, Princess in the garage,..Question before it’s too late, I feel like I will be happy with the princess as far as burn time and heating but I’m curious if there would still be an advantage to buy the king. I guess a concern for me would be burning at a lower setting more often might cause more issues than advantages . Think I still have a minute to change if there’s a good argument for the king. Thanks ahead for input
Wait! If you do not have a straight up and out install (all vertical) and have wall exit, stay with the Princess. The added elbows of 8" on the King could result is a draft issue.Hmm, so my concern wasn’t correct. I’m going to give a call and see if too late and what the actual price difference and if the extension brackets will work for 8” on my overhang. Should open at 10. Not sure I really need the crazy long burn times but if it doesn’t effect the creosote issue wth
BKVP
I’ll say the global warming that’s happening in my area is making me think $3000 for a bigger stove is worth it hahaFor what it's worth, it's amazing how much heat the surface of my Chinook 30 (same firebox as the Princess 30) radiates. True, it's not single digits out there and the house is quite well insulated (for Southern standards), but even so it's way too easy to overheat the house. The king probably adds a whole new dimension to that...
So finally got a minute, busy day. So a king can’t be installed in a through the wall setup? I’m feeling confident the princess will be a good match for my home but a king would look really cool and give me bragging rights to my buddies of a potential 40 hour burn not that I really need such a thing. 12-15 is my away from home work schedule . Probably have to open some windows here and there but I get wood for free . Anyways, just curious really
It isn't that a KE40 won't work. You might have to build a chase/insulate the outside sections of chimney to keep stack warm. You can install it using all recommendations in the manual, including running as much vertical off the stove as possible, then 2 45's to wall thimble, then a "t" and up. If the stove lacks draft....you may have to insulate/enclose the stack of venting outside.Ya, there’s no place to install through the roof. It does have a 12/12 roof and 10’ ceilings on the first floor though. Although I’m going to have to raise it up off the floor to get above the foundation wall for fresh air intake as it’s a slab floor so that screws the 10 ft thing. I’ve got one of the lead installers coming over on the 18th to hopefully eliminate another setback. I probably should have just got a pellet stove but free firewood is a hard argument
It looks to be the same for the princess in the install manual?
