she got home from the Church Lady's house
The same phrase popped into my mind, when I read Poindexter's post.Couldn't resist. How many here remember?
Surprised you're so much warmer than us, as you're 35 miles north, and at least 60 miles closer to water than me. Our high yesterday was within a degree or two of 90F, actually I think it officially hit 89F. Our forecast overnight lows this week are 15F below yours. I'd expect your proximity to water to moderate the highs, and your position farther north to have you at a lower average, than my position NW of Philly.Yesterday, 94 F, with the perception temperature (due to humidity, whatever trademarked brand each weather app has...) of 109 F here.
Rest of the week a pleasant 81-ish with a low around 70. Any burning will have to be outside for a while.
I read the temperature on 2 gauges, and my AccuWeather app said the same.Surprised you're so much warmer than us, as you're 35 miles north, and at least 60 miles closer to water than me. Our high yesterday was within a degree or two of 90F, actually I think it officially hit 89F. Our forecast overnight lows this week are 15F below yours. I'd expect your proximity to water to moderate the highs, and your position farther north to have you at a lower average, than my position NW of Philly.
I spent the second half of July on LBI, and water temps there were in the upper 50F's, so it definitely ain't the Atlantic keeping you warm!
Of course it is! It was 70F the day we arrived, and proceeded to drop 3°F per day, each of our first four days there. It never went back above 63F for the remainder of our vacation.The water temperature at the South shore is just below 70 F right now.
Apparently thats the msrp I was quoted. Which brings me to my original thoughts. Is a stove this $$$ worth the extra money verses a non-cat, but still epa listed stove such as a $1500 drolet? Or 1k more that a same size Kuma?Wow, $4400 for a 20.2? Does that sound right?
I just used the Drolet for an example I dont know the output. I'm no stranger to wood stoves, Ive been burning since 1988. I have a englander 13ncl ( 1.6 cu ft box) in a 20x40 insulated, but drafty, pole building. That smallish stove will easily heat that building to the low 70's when its -10f outside without much babysitting. In comparison, I know that same stove would easily heat the upstairs ( 32x40) of my home which is much better insulated coupled with solar gain. Getting enough heat isnt my issue as strange as it sounds. Rather, getting too much heat is. Currently I have a wood furnace thats responsible for my heat, also I have a LP furnace. The wood furnace puts out a lot of heat once it gets cranking. I generally let the furnace go out during the night and my home will hold the heat the entire next day until the sun sets, then the home will start to cool. I usually wake up to a inside temp in the low 80's and when I re-lite the wood furnace it may fall below 70 but that depends what time I lite the furnace again. If I had to burn my wood furnace 24/7 my property would look like a desert instead of a woods.Do you know the range of BTU outputs that the drolet can produce?
The Kuma is a good contender imo.
The drolet is a good stove, but can it do what you need it to do?
To me no, I’m around all day to feed my stove as needed, I don’t need 24 hr burns. if your busy or working most of the day a Blaze King long low burn is a great thing.Apparently thats the msrp I was quoted. Which brings me to my original thoughts. Is a stove this $$$ worth the extra money verses a non-cat, but still epa listed stove such as a $1500 drolet? Or 1k more that a same size Kuma?
