Installed a Englander 25-PDVC in a corner position with a 45 degree and 3 feet of horzontal pipe straight out to a horz cap. Air intake is about 2-3 feet of flex 2" pipe to outside. I did a test burn this morning. Burn went very well but I noticed a very active flame with a lot of sparks leaping from the burn pot. Even had a few sparks existing the vent cap at the start of the burn. No black smoke at all and a very clean burn with a 4-5" active yellow flame with a little blue at the bottom. Are the leaping sparks normal or a sign of too much combustion air for this stove?
I bought the stove (almost new) from a friend which came with the typical duravent kit. I tried to install the vent piping system per instructions to come out the side of the house and then up 5 feet with a 90 and vent cap but could not get the Tee to line straight up when everything was twistlocked into position. What I currently have is stove -> pipe adapter ->45 Elbow (with swivel on stove side) -> 1' straight pipe through wall thimble -> 2' straight pipe -> horzontal cap.
I have a cleanout Tee (with no swivel) that will not line up properly when locked into the pipe (off at about 30 degrees from vertical). Am I missing something?
