Hi All,
A bit new to burning. I have about 2 seasons under my belt with my new Dauntless stove. I have a full stainless steel liner in my chimney that is about 23-25 feet approx.
I had an incident last year where the T that comes out of the back of my chimney started glowing red, my guess was a small chimney fire from all the build-up over a month of burning non-stop. I get my liner cleaned every season as well. Occasionally after that happened, I let the stove go completely out I will take the bottom cap off the T and clean that out and also take a vacuum and suck out all the creosote from the stove pipe itself that goes into the T.
The wood I am burning is seasoned as it has been stacked under 2 tarps for 2 years and was seasoned when it was delivered and the previous owner of the home had 3-4 cords stacked and ready to go as well. (Still could be damp I guess, but I am a newbie)
ANYWAYS, this happened AGAIN this morning to me and it was crackling so loud and sparks were coming out of the cap on the bottom and it was glowing red hot again. What is the protocol you recommend?
Here is what I did:
Shut damper down completely
Turn air vent off completely
Did not call the fire dept
Moved family out of the room
Watched the temps go down.
The pipe isn't too discolored or anything right now. How do I prevent this from happening? How often should I do a full cleaning? I know every set-up is different but I am hoping some people here have some experience with this. I appreciate any help.
Here is what I did:
