I have the same stove ,three lower buttons set 1-2-1 runs great give it a try.So I have had my 25PAH englander Room Heater for about 5 years. I love the stove but I have never been able to figure out why the burn pot clogs constantly. It gets filled with a lava-like substance I have to chop out with a putty knife. I have tried every different type of pellet available from super cheap to the most expensive and it makes no difference. Every 2 days I have to shut her down and clean the burn pot. It doesn't matter if the stove is on 1 or 9 for feed rate. I also have the 25ep summers heat on the other end of the house and that uses the same pellets and I could burn trash in there and it almost never has to be cleaned. Installations are different - the 25pah is direct out the exterior wall and the 25ep has a stainless flex pipe inside the chimney that goes up through 2 stories and attic before it discharges. Both stoves are set the same for the bottom 3 control buttons by factory. Any suggestions to make the EP burn without clogging the burnpot?
Sent from my SAMSUNG-SM-T377A using Tapatalk
