I'm in the early stages of planning my install. I bought a used Blaze King which is going on the first floor. I plan to use double wall stove pipe up into to second floor bedroom. The second floor will be class A double wall in a chase. The chimney will continue up into the attic and then through the roof. I'm confused about the floor penetrations. The first floor gets a ceiling support box which also converts from stove pipe to chimney pipe. Is the second floor ceiling just a radiation shield or should this also be a ceiling support box. My ceilings are 8'. Also is it worth it to build an insulated chase in the attic or is the class a sufficient for the cooler temps. (New Jersey).
Sent from my SM-G950U using Tapatalk
