I will be installing a Lennox Earth Stove model 1500HT into a manufactured home. I read and re-read the manual and it does not seem to mention anything about building a "heat shield" for the surrounding walls behind or on the sides of the stove. I am planning to do a corner install and the only directions that I can clearly see are that I need to have a non-combustible hearth pad with the specified dimensions, that the pipe needs to be 13 inches from the walls, and the stove corners need to be at least 5 inches from the walls.
Is that all I need to worry about? Any help you can offer would be greatly appreciated!
.pdf
