I have an OWB.  I am in the process of installing a Primary/Secondary system with the primary pump in the house rather than on the boiler.  I'd like to locate the primary pump for my system as near to the basement floor as possible to take advantage of the natural pressure to be gained by having the pump as low as possible below the boiler.  My pex enters the basement by the ceiling.
My plan was to put a 90 on the pex source and come down the wall, through the manifold and then into the return. I'm wrestling with a question and would appreciate some advice.
If I mount the pump by the floor I assume I'd have to use a couple of 90's to make a loop and come back up the wall and then use a 90 to go into a horizontal manifold. I would then need 2 more 90's after the manifold in order to connect into the return. I'm trying to keep my head as low as possible. All of those 90's won't help.
I was wondering what the ramifications are if I were to mount the manifold in a vertical position with the secondary pumps coming off the side rather than above or below? Would I introduce problems with ghost flows? Bad idea?
Forgetting my question about the vertical manifold, if you were designing this primary/secondary system where would you position the primary pump on the wall and how would you plumb things? I have to keep the primary system as free of 90's, and other things that would increase head, as possible. The pex size for my main loop is slightly under sized.
Thanks!
Thanks!
