52i not burning like it did when it was new
Chetscapes
4
Fredrick
My pellet stove doesn’t seem to be able to blow the ash off the burn pot like it did when it was new. I am not sure how often you need to replace the seals around the door and around the docking pipe I have owned it for over four years now and burn 3 tons of pellets per year. Does the combustion blower need adjustments with age?
I watched the video on scraping the burn pot what a pain in the rear end. My RV 100 C I clean it every 4 or 5 days and never have to scrape the burn pot in between cleanings and there's usually no clinkers in the pot.
52i's do not "blow the ash off",it is pushed into the collection pan/pot.Perhaps a better description?
Yes,you have a great stove.As far as scraping the pot on a Harman,"in between cleanings",you open the door,while the fire is on low burn,scrape for 15-25 seconds,then shut door.I actually do the same thing on my Integra.
You may still have some restriction,in the flue,or combustion air intake.You also may have a weak exhaust probe.You may also have a weak combustion blower motor.A Harman technician,with the Harman diagnostic tool,could check these things.
