I've never had, or installed a woodstove and I feel like I'm leaping off a cliff but its time to start the install! I have read and researched so much and talked to friends, family, and the stove store owner, that I feel pretty good about doing it myself. I'm a welder by trade and have a background in construction so I'm not entirely out of my mind, lol.
I'm here asking for advice from people who have been there and done that. My motives are almost entirely self serving; better heat, cheaper electric bill; happy wife; etc etc...the whole clean energy thing is awesome but not the main motivation. I find this forum to be an excellent source of raw information and opinion, but as of yet I've no idea how to filter the "truth" and the "bs" and different things work for different people.
So onwards to the plan:
I'm ready to start buying supplies to begin installing my tl300. While I've been researching for a while and have a solid plan in mind, I would like to see if anyone has any ideas or can offer solutions for an obvious problem(s) with my plan.
I'm doing a corner install and building my own hearth pad; what I have in mind is a 2x4 frame that I will anchor to both walls and the floor. 1/2" durock on top of that, finished with porcelain tile (.413" thick) sides to be trimmed with wood to match the room.
Following the owners manual for the Harman tl300, clearance to the walls puts my installation in a bit of a bind. From the corner of stove to nearest wall has to be 18". When I measure everything out, my support box is going to run into a rafter. Easiest clearance is to move the stove 2" closer to the corner, for 16 9/16" from corner of stove to the wall instead of 18". My thinking at this point is to put two 15° dw elbows together to make clearance. I'm not at all sure that will work, but its the best idea I have. Because my install is off corner pulling it forward would require it to be way to far out in the room. If the double elbows won't work, I'll probably install it slightly against recommended clearance, unless someone can offer a better solution.(major construction to the ceiling/roof are not viable options at this point) I'm hoping someone has an elbow in their chimney pipe and can confirm it doesn't effect draft too much. If I do have to violate clearance I will install some corrugated sheet metal with 1"spacers.
As for the support and pipe, I go tomorrow to talk to the Harman dealer and order everything I need. I do know that the manual recommends 16' above the stove. I plan on going 16' to make sure my stove gets the correct draft(hopefully) and need some advice on how many chimney supports to install. There is about 6' from top of stove to the ceiling so I'm going right at 10' above the roof, and I'm planning on one support at the 5' mark, but should I put two supports on and devide the difference equally? (like 3.3 ft and 6.6ft?) I just don't have any experience with this and have no idea how much it might blow around.
I'm sure there will be more questions to come and so I'll end my book here. Thanks in advance for those that take the time to help out a newb!
