8 to 6 reduction
Dmitry
1,228
CT
I might have a chance to sell my Large flush Travis hybrid . I’d like to get something bigger and bolder . Can I instal something like Buck 91 with 8 to 6 reducer I have 15 feet of smooth wall insulated chimney , interior location, never had problem with draft .
No
Can you elaborate a little? I want to get some education on a subject. Is it possible lack of air coming trough firebox? I see Largest Kuma inset is only 3.5sq ft Vs. mine 3 , but requires 8 inch.
For proper draft you need to match the outlet. By downsizing you are reducing the volume but increasing the velocity doing so can cause overheating or lack of draft.
Damn, it makes sense . Any insert you can recommend that big and deep enough to load N//S ? And yeah, 6 inch flue lol
Osburn 2400i is big enough to load north and south.
Some of the PE/Alderlea non flush inserts (Super, Summit, T5) as well as the BK Princess can be loaded N/S if split size is under 18 inches. I believe some of the larger Enviro inserts can be loaded N/S if under 16 inches.
You could look at the High Valley inserts, too. The 2500 is a 3.5 cu ft cat stove that has an 8" flue but specifically states it can be used w/ 6" reducer.
(broken link removed to http://highvalleystoves.com/insert2500.php)
Another that is worth considering, despite being only a 3.0 cu ft box, is the Harman 300i. It's not a cat but gets long burn times (12+ hours) with its afterburner technology, and is supposed to be a heat monster. I know some have said it's tricky to get working and you have to be careful with the fragile afterburner (and remove the insert once a year to clean behind the afterburner assembly). All of that said it's still one I personally considered until I realized the sidewall clearances make it a no go for me. It's pretty much the same thing as the Harman TL300 stove minus the top load, so you can YT vids of that stove too if curious.
Not the biggest viewing area but it's quite tall. I think it's 13.5 by 13.5 or so.
http://www.harmanstoves.com/Products/300i-Wood-Insert.aspx
They're all good, but not really a game changers. may be I should not fix what is not broken.
I honestly think the Harman inserts and stoves are some of the worst on the market now. I would never recommend them
Whys that? Just wanting to know for future reference.
Their combustion system is overly complicated and delicate. That makes it very hard to learn how to fun properly. As well as difficult and expensive to maintain
Thanks!
Also their inserts have through bolts on panels that need removed to clean the combustion chamber. This means you need to pull the insert and remove the convective jacket to clean it properly. We have welded the nuts fast on the back of several so they can be maintained reasonably.
Reactions: redktmrider
