Really?trylon said:I've tried Wood Brick Fuel by US recycled wood products and feel their bricks are even better than biobricks from TSC. Just my opinion. Mostly used mixed with questionable wood in my stove. (broken link removed)
HotCoals said:Really?trylon said:I've tried Wood Brick Fuel by US recycled wood products and feel their bricks are even better than biobricks from TSC. Just my opinion. Mostly used mixed with questionable wood in my stove. (broken link removed)
I have tried both and I find it the other at around..but eh..maybe your stove is that much diff..I dunno.
Eco-bricks is what I bought from TSC.
AndrewInCT said:If you build a wall with them (so they become almost like one log), you can get some pretty decent burn times out of them.
kallsop said:AndrewInCT said:If you build a wall with them (so they become almost like one log), you can get some pretty decent burn times out of them.
I burn Envi-8 Blocks and agree - if you align the blocks so they become one bigger mega block, it then burns like a larger piece of wood and you get longer burn times. You are arranging the blocks to get minimum surface area, so there is less exposed wood to burn. It will still get plenty hot. The Envi's are all hardwood and I think the Bio's are a mix of softwood and hardwood, so the Bio's I would guess will not give quite as good long burn times.
BeGreen said:Burned correctly I found the Bios gave good burn times and there were coal like embers for a restart. Not as good as a real hardwood fire remnants, but not all that bad. It may take a little more practice to get them burning right. They should be layered like kallsop described, with the new layer placed at right angles to the one underneath it. That makes it a more solid wall with less air passages.
trailrated said:I've been playing with them a bit. I'm not that impressed. They burn well, but leave you hardly anything to restart with like a hot bed of coals do. I've been using them to fill small voids in the firebox to better pack the stove.
BeGreen said:SuperCedars are great for starting highly-compressed bricks and logs. They make it easy.
