I am not totally satisfied with my old insert. I want longer burn times(3 hours max.now), less creosote, less wood consumption and less heat going up the flue. It just pours out the flue in the cold weather. A chimney specialist said he would put a 8" insulated liner connected to the stove with top plate and that would help especially the creosote issues. In fact no more creosote. Probably for around $1700.
The only new modern stoves available are 30 miles away and are lopi at a patio and spa location. I think reputable with stoves and been in business a long time but high, high, high
Their deal is 6" uninsulated liner, top plate, lopi freedom bay with blower, trim panel, black door for $4200. It would take 3 years of burning for payback as propane is not real high here. $1500 next year(2.49/gal.) Last year $1000. at 1.79/gal.
My chimney is interior river rock with 12x12 clay flue and excellent draw. Would the insulated 8"liner in old stove help put more heat into room (less draw) and less creosote above roofline. Or would the new stove in fact put out more heat, less creosote, and less wood were it would be worth the 3 year payback. Other facts. No one does block off plates. As far as issues with the creosote it is the hard glaze above the roofline. I clean it myself every year and can get it clean except for the hard glaze. As far as insulating the new liner chimney specialist says it would help safety by helping insulate hot flue liner from creosote on tile. New stove dealer says on interior chimney do not need insulation and of course would be more than $4200. Oh and also the chimney specialist can get napoleon or drolet but I have ruled that out as my wood is cut too long and big so I want close to a 3.00cu ft. firebox. My country flame insert is 4.3cu.ft. double glass door, baffled air flow out sides and top. Throws out alot of heat but you have to FEED it to keep this heat going.
I'm concerned with the new stove that I won't be pleased with it in different ways that I wished I kept the old one. I have asked the modern stove store to give me a couple customers names who bought new stoves to replace old stoves to ask them if it was worth it but they haven't got back with me on that in 6 weeks. I could be happy i guess and keep what I got and be okay and spend no money. Afterall, the whole idea for me is to save money. Please help with ideas and recommendations if you can. Thanks Tony
Their deal is 6" uninsulated liner, top plate, lopi freedom bay with blower, trim panel, black door for $4200. It would take 3 years of burning for payback as propane is not real high here. $1500 next year(2.49/gal.) Last year $1000. at 1.79/gal.My chimney is interior river rock with 12x12 clay flue and excellent draw. Would the insulated 8"liner in old stove help put more heat into room (less draw) and less creosote above roofline. Or would the new stove in fact put out more heat, less creosote, and less wood were it would be worth the 3 year payback. Other facts. No one does block off plates. As far as issues with the creosote it is the hard glaze above the roofline. I clean it myself every year and can get it clean except for the hard glaze. As far as insulating the new liner chimney specialist says it would help safety by helping insulate hot flue liner from creosote on tile. New stove dealer says on interior chimney do not need insulation and of course would be more than $4200. Oh and also the chimney specialist can get napoleon or drolet but I have ruled that out as my wood is cut too long and big so I want close to a 3.00cu ft. firebox. My country flame insert is 4.3cu.ft. double glass door, baffled air flow out sides and top. Throws out alot of heat but you have to FEED it to keep this heat going.
