Absolute 63 Harman digital display
Jim S
10
NJ
Hi all,
The minimum feedrate that I can control on the digital control is 25%. Does anyone know how to override this rate to bring it lower? For example, when my room hits the right temp it lowers itself to about a 6% feedrate. I would like to lower my feedrate manually to have a nice slow burn on some days when the Sun is beating on the house to warm it up and I don’t want it burning at 25%. Thanks for any information.
JS
Hi all,
JS
I just checked and there is no option to adjust feed rate on the dealer screen so I'm guessing you can't set a max feed rate below the 25% you see on the feed rate screen. I'd change to constant burn mode and set it to a lower setting to get it close to the 6% when it's just maintaining.
I have a absolute 43-C and I can control mine. I have the digital control on it. I go to the feed limit icon and slide it to what limit to what you want. I set mine @ 39% and possibly I could lower it when it gets a lot warmer etc. But I never change it. I think you adjust it to get the 1" at the feed pot edge?
Thanks. I may need to just come off the wireless sensor on days that I want to run at the lower rate. Thanks for the insight!
I can lower it but the lowest is 25%. I think to go lower I will need to go to constant burn and go as to 1 as a setting.
i just tried constant burn and even at a setting of 1 it is a 25% feedrate. It would be nice to override and bring to 10%
