Accessory Chimney Opening in Kitchen that is now closed off.
jadz
2
Nova Scotia
Hello everyone! My first post.
I have just purchased my first home which has a two flue chimney. I pan on putting an insert into the Fireplace, which is one one flue. The second flue is connected to the oil furnace in the basement, but also has a 'thimble' (?) opening in the kitchen which has since had a metal cap put on it. I assume this would have been for a kitchen stove at one point?
I am wondering what the proper way to seal up the opening would be?
  • [Hearth.com] Accessory Chimney Opening in Kitchen that is now closed off.
i think what your asking about is called a flue stop. or at least that is the easiest way to do it:
http://www.sandhillwholesale.com/wo....html?osCsid=e976842dbe9aae1a73a0220d909506df
(broken link removed to http://www.acehardware.com/sm-imperial-flue-stop-bm0353--pi-1274074.html)
considering where it is, you may want to silicone it in.
for come extra work.. i'd probably cut a circile of sheetmetal, leaving 3-4 tabs to help wedge/attachit in closer to the furnace flue, then attach on of the above items for neatness.
Not to step on toes here, but there is a much better and safer product than those for this purpose.
(broken link removed to http://www.kschimney.com/store/product.php?pid=213)
Insert, tighten screw and the flue is sealed air-tight and insulated from the dwelling. Eliminates the need to furnace cement a flue stop in and is definitely going to seal better.
man, you can step on my toes any day. you the man.
(i was searching for something to answer his post, and bored at work, knew there had to be a better answer).
I was actually thinking that it might be good to block the opening to the thimble at the flue, as it currently acts as a bit of a shelf that debris can build up on (which after re-reading moondogs post is what he was suggesting too).
When I took of the cover that is there now (made of galvanized metal) there was some buildup in the opening.
