Almost exactly a year ago, I replaced a fireplace remote with a new one by Acumen. It was professionally installed. I noted that it shuts itself down after 7 or 8 hours and discovered this was how it was intended to work. Recently, it has been shutting down after only a couple of hours, and then doing so twice and not turning back on. I called the installer who said to change the batteries. I didn't even look at it, because I know how it works when it needs new batteries, and this wasn't it. I stupidly continued to use it. Finally last night, it happened again and I decided to change the batteries, upon which I discovered that the batteries were bulging out of the back of the receiver, I couldn't open the battery compartment, and the whole thing looked distorted by heat. Pretty alarming! I was afraid to mess with it too much and had trouble disconnecting it from whatever the piece is that it is connected to, so I turned off the pilot light, because honestly I was afraid to go to sleep leaving it as it was.
I can't find any info about a warranty, and am going to call the store, but I suspect they will offer to charge me a couple hundred for a service call and for a new machine. Does anyone have contact info for Hearth, which apparently owns Acumen? I tried searching online, but got nowhere.
Final weird question: a few months ago, I noticed that all of the fake logs had moved. These things hadn't budged an inch in eight years. They sort of fell over. This fireplace is in a formerly working wood fireplace with a real chimney that is vented. Could it really be wind? Or was there something more ominous in terms of the gas going on? Thank you!
pics attached
![[Hearth.com] Acumen remote - batteries expanded, whole thing is distorted [Hearth.com] Acumen remote - batteries expanded, whole thing is distorted](https://www.hearth.com/talk/data/attachments/312/312446-379916df20ee32f1aa794a43d62e5eae.jpg?hash=q395xW5z5U)
pics attached
