I'm about to replace the door gasket on my wood insert. It's been a while, but I think I've used the red silicone adhesive in the past with good results. The typical cement that you see in hardware stores associated with gasket replacement seems to be the hard silica stuff, although admittedly I didn't look close.
I'm thinking I should stick with the high temp (although the door probably gets hotter) silicone.
What do you think?
Thanks.
What do you think?
Thanks.
