I recently bought a home which has a double chimney for the basement and first floor. The basement is unused and brand new. Upon taking apart the woodstove piping on the first floor (it is a Hearthstone Phoenix), I realized that the thimble on the first floor which is directly in the center of the home, is actually not in the center of the chimney flue, but rather the center of the double chimney. They obviously messed up during construction. So, the actual flue designated for the first floor is to the left of the thimble. I have attached a photo. If you look inside the thimble, the actual flue is left about a foot. The orange clay liner is left a foot and about 5 ft or so higher up and appears to be rectangular to the top of the chimney.
The prior owner actually just had a single wall pipe resting in the thimble, which is obviously not good being that A) it is an exterior chimney and liner much larger than the 6 inch woodstove, and B) the exhaust literally has to make a hard left to then exit through the top some 25 ft higher .
My question is, what in the heck do I need to do here?
A flexible liner option is out because I cannot get it around the corner and the cleanout is not reachable from the basement cleanout door. Do I tear down this chimney and install just a single lined chimney that is properly centered? Do I move the thimble to the left (properly lined up) and install a steel liner?
I am very frustrated by this situation because the home is new and the chimney is about 25 ft high (A Frame), and I feel like I should have better inspected this prior to purchasing the home, but it wasn't even a thought.
Any help is appreciated.
![[Hearth.com] Advice Needed - Awkward Chimney/Hearth setup [Hearth.com] Advice Needed - Awkward Chimney/Hearth setup](https://www.hearth.com/talk/data/attachments/190/190273-eacad54a35408cb2a8b9c5ccab99a8a8.jpg?hash=aSBgz856c4)
![[Hearth.com] Advice Needed - Awkward Chimney/Hearth setup [Hearth.com] Advice Needed - Awkward Chimney/Hearth setup](https://www.hearth.com/talk/data/attachments/190/190279-7c6eb8f2e063deae0988ff1ad73fe087.jpg?hash=KxVP8V9fh_)
![[Hearth.com] Advice Needed - Awkward Chimney/Hearth setup [Hearth.com] Advice Needed - Awkward Chimney/Hearth setup](https://www.hearth.com/talk/data/attachments/190/190280-76f703211180eb10609693621725f1e4.jpg?hash=7jI58GmD4j)
