did any of these contractors do a load calc? with mini splits it is crucial. they don't have the dehumidifying capacity as a normal ducted system would. so it needs to be sized right.
None of the companies I talked to offered this solution. After bigger storms I would have to go outside and shovel the snow from the unit, which would sit on a concrete pad at ground level. Maybe I can convince them to elevate it atop pressure-treated lumber or concrete pavers to buy me at least a little extra clearance.
But There is a slight vibration coming thru from the outside wall. especially in the heat mode.
It's a pretty minor vibra/noise. The house has to be dead quiet to hear it.Wondered about that. Kind of going full circle -- get a mini split to get rid of the window shaker aspect of window/wall units, then hang the outside unit on the wall and end up back where you started.
is it the unit itself or the refer line vibrating? it is common for the line to vibrate.It's a pretty minor vibra/noise. The house has to be dead quiet to hear it.
Ill say,My cooling cost are about $40 if that for the whole summer while heating costs are many many times that amount when heating with anything but wood. About $1000 minimum.My homes Cooling Capacity is 22000 BTUS while heating is 95000 BTUs.Not really.....your cooling loads are prob half of your heating loads.
Ill be sizing my minisplit for heat, which will be more than enough for cooling.All 3 companies did load calculations, which is why I was surprised by their very different conclusions. I called Company 3 back, and he indicated that he has installed thousands of units over the past decade and stands by his load calculations. He mentioned that he sized the units for AC, and by doing so, it will be more than enough for heat. Does that sound logical?
somewhat.All 3 companies did load calculations, which is why I was surprised by their very different conclusions. I called Company 3 back, and he indicated that he has installed thousands of units over the past decade and stands by his load calculations. He mentioned that he sized the units for AC, and by doing so, it will be more than enough for heat. Does that sound logical?
you also give good advise. sometimes, more than it should be, installers only know how to install. that is strictly what they do. some of the bigger company's around here won't let the install crew start the unit's. they are not trained like the techs or sales guy. if you want the real skinny on a product, talk to a good tech. they will most likely know more about it than the installer or salesman, and sometimes more than the manufacturer. lol. the tech can tell you reliability of a product and common issues.You are getting a lot of good advice hear - nothing to add except that it is ok to go slow - just install one unit for now if you are worried about cost or want to see what the payback is like. One 18kBTU unit downstairs will throw a lot of heat (more than 18kBTU when temperatures are above freezing) and be the least cost option. You can always add more later if you want to.
Personally, I would get the Hyper Heat since I am an efficiency nut, but you'll still be plenty happy with the regular ones, especially if you are worried about the extra cost.
I personally wouldn't put much faith in what the installer says about Hyper Heats...the installers I talked to were remarkably unawares of the specifics of their products. I had to educate them and even specifically write down what I wanted them to quote me. It was a big eye opener. I would say that the quality of the advice you are getting here is likely better than what the installers are telling you.
The company that suggested 2 units proposed: MXZ-2B20NA 2 port outdoor unit MSZ-GE12NA indoor unit, one on each floor The company that suggest 3 units proposed: MXZ4B36NA-1 outdoor unit MSZ-GE24NA indoor unit downstairs MSZ-GE09NA-8 in each upstairs bedroom.
and only 12,500 btus at 17
and has an HSPF of 8.9 and a SEER of 18. Meh
and 22,000 btus at 17
. I think the HSPF is 9.3 and the SEER is 17.5 but I'm not sure as my Mitsu catalog is a little vague with this unit.
and 15,000 btus at 5
and has an HSPF of 12.12,000 btus cooling and SEER of 25
and 17,000 btus at 5
with an HSPF of 12 also. 15,000 btus cooling and SEER of 21.5
. We use essential cookies to make this site work, and optional cookies to enhance your experience.
