Just got a Vogelzang Colonial delivered. I'm DIYing the install and am wanting to order the liner now. I've read a fair amount on this site and others about liners and installation, including of course sometimes conflicting information (I can live with that: part of a democracy, I guess!). Three questions:
1. Best removable way to seal smoke chamber?
The instructions for the insert indicate that I should "seal smoke chamber" but that "accomodations for inspection and cleaning should be maintained," which I assume means the seal should be removable. Now, I'll be sawing a gap in the cast-iron damper frame that is there near the smoke shelf to make enough room for a 6" liner (I removed the damper flap so there's an open slot there already, but just maybe 4" wide or less). I've seen pics on hearth.com and elsewhere of people fabricating steel sheets as a smoke seal and "flue gooing" them in place around the liner, apparently with some sort of insulation on top of them. But this seems rather permanent. Is there some removable way to go about this, and perhaps an easier way, too? Call me a dreamer, but is there some sort of rigid insulation material that would work just by itself, and be fastened there so that it could be removed easily? I will also be getting it inspected by my city, so I suppose it might be good to do something that looks a bit "standard."
2. Would liner insulation really help?
My brick chimney is in the middle of my house. My house is one story, with an unfinished attic. It goes up through the attic at about the top ridge of the roof and extends about 3 feet. It's built together with the chimney for a second smaller fireplace in another room (the flues are totally separate, and the other fireplace will remain as is). The liner will be 15' long. I've read in some accounts that liner insulation is not necessary in chimneys that are not on an outside wall. Furthermore, I'm in Seattle area, where it's not generally very cold. How helpful would liner insulation be in my situation?
3. Any reason to put an inline damper in the liner? I see they're sold. Haven't read about any other owners of this model doing that.
