This is from 7am to 3pm temp was still 600.
You are very lucky! That is what mine looks like from 7am to 10 or 11amView attachment 150628
No block off plate but when I had the old stove installed the installer but insulation. Yes I took the knockout plates out.That's what ours looks like from 8am to 1pm :/
Wolves, do you have a block off plate in your chimney? I know you have the reducer plate in, but do you also have the knockout plates removed?
Thanks!
Yes. That seems to be working fine. Maybe the short burn time is from lack of insulation. Where should the insulation be? I watched the installers put in the insert and tubing up the chimney and there was no insulation put in.When everybody that is having a problem close the air do you see a difference in the flame?
Insulation was on the top of the fireplace. Did the installer run the liner all the way to the top?Yes. That seems to be working fine. Maybe the short burn time is from lack of insulation. Where should the insulation be? I watched the installers put in the insert and tubing up the chimney and there was no insulation put in.
I will bring up about insulation with the Regency rep and the installer at my house tomorrow. And yes, the liner went all the way to the top.Insulation was on the top of the fireplace. Did the installer run the liner all the way to the top?
Can you please post what the rep tells you?I will bring up about insulation with the Regency rep and the installer at my house tomorrow. And yes, the liner went all the way to the top.
I don't remember do you have the reduction plate and the knockout plate removed.Our liner goes all the way to the top but the dealer did not put in a block-off plate or any insulation, from what I could tell.
With the probe temps I bring it to 550 close the bypass then when temp hits 700 close the air. The temp will slowly rise to about 1,100 to 1,300.I don't have the plate installed or the knockout plates removed. It's stock. I want to get the probe installed before I start making mods to the stove.
Love this forum guys, lots of good advice. I have had the CI2600 now since mid Nov. I have never had a wood burning insert before, just an open fireplace. I am still learning how to burn efficiently with this thing but i must say i love it. I am now getting a good 10hrs of heat. I have attached a "so called" burn diary. Its a typical burn for me. Any comments or advice "wood" be greatly appreciated. My opinon only to those who are having only 4 hour burn/heat times is to keep plugging away and experimenting, cause i too was just like you.
This is ours from 4pm to 8pm with temp at 550 . Hopefully the changes will help next week. And this is with the rep checking it out and cramming it full if wood.View attachment 150628
No problem. The knockout plates can only be accessed by removing the faceplate. It's on the right and maybe also the left side of the firebox toward the side back. It's perforated and just needs to be pushed out. However, because you have to removed the faceplate I wouldn't do it or have my husband do it. I'd have the installer do it. The rep does not recommend taking the andirons out. But he did put the wood over it and almost touching the glass. Hope that helps.Cinders thanks for the pics/instructions and the info about what your rep said. Anyone out there know If they they recommend taking the andirons out and filling the wood to the glass. Also I'm not sure if my knockout plates are in or not. If they are in is it recommended that they are removed. I have no idea where they are located so if anyone has pictures or details where to find them I'd appreciate it. My unit is burning pretty good. I'm getting on average +- 8 hours between loads with good heat being put out. That's with the andirons still in and not loading up to the glass. It was pretty chilly the past week. Lowest being 0 degs and was able to keep our living room between 67-70 deg the whole day.
I am also running with a stock unit - andirons in and i believe knockout plates still in (no idea where they are?) - and getting similar burn times. The only thing i have done to the unit is I have removed one set of washers from the door. I think i might try and do what the rep did for cinders and load up and over them.Cinders thanks for the pics/instructions and the info about what your rep said. Anyone out there know If they they recommend taking the andirons out and filling the wood to the glass. Also I'm not sure if my knockout plates are in or not. If they are in is it recommended that they are removed. I have no idea where they are located so if anyone has pictures or details where to find them I'd appreciate it. My unit is burning pretty good. I'm getting on average +- 8 hours between loads with good heat being put out. That's with the andirons still in and not loading up to the glass. It was pretty chilly the past week. Lowest being 0 degs and was able to keep our living room between 67-70 deg the whole day.
Now correct me if i am wrong but isnt removing the knock out plates going to add more fresh air/draft to the firebox thus making the burn time decrease. Anyone running without knockout plates for sure and getting longer burn times?
