Can someone with an AF Integra bring me up to speed on whether or not to fully gasket the glass across the bottom middle of the glass panel? It's obvious that the top sections are not gasketed to allow air to flow between the frame and glass for the 'air wash' action, but the bottom is where I'm confused.
There's a metal plate with a lip at the bottom (in front of the burn pot) which seems to allow air to flow in at the center bottom section and flow up and across over the burn pot, but that could just be because the previous owner didn't install it right.
So, do you gasket all the way across the bottom to completely seal it up, or should that middle 'lip' be open to allow airflow the way the same way the tops are open?
Thanks in advance!
Thanks in advance!
![[Hearth.com] AF Integra: Air Wash & Gaskets [Hearth.com] AF Integra: Air Wash & Gaskets](https://www.hearth.com/talk/data/attachments/117/117927-c2d6b71ddf13cf2deea54a6c8e6d418b.jpg?hash=PcFlx8Vuac)
![[Hearth.com] AF Integra: Air Wash & Gaskets [Hearth.com] AF Integra: Air Wash & Gaskets](https://www.hearth.com/talk/data/attachments/117/117928-7bd1c067da7180579d189bb6310038c6.jpg?hash=Dv6bOXa0a5)
