Affordable Quadra Fire Blower Replacement??
olgreyhair
22
NE PA
Hi all. We have a Quadra Fire 41I-ACC-BK wood insert that is now 8 yrs old. We run this stove 24/7 from November thru April around here.
The blower motor is still going, but I would like to find a replacement before it quits. It's Quadra Fire part number SRV7045-013.
I can find the blower motor online, but they're over $400.00!!
There has to be a more affordable alternative. I hope. Any advice would be appreciated.
Thank you for your time. George
bholler
Chimney sweep
Staff member
Jan 14, 2014
32,862
central pa
Pull the blower out and get the actual part number off the blower
begreen
Mooderator
Staff member
Nov 18, 2005
102,482
South Puget Sound, WA
Is this the Bodega Bay insert? If so, the blower is very expensive. It would be worth seeing if the fan motor itself is replaceable. Otherwise, you may need to see if Grainger sells a long squirrel cage fan of approx. 180 cfm that will fit on the base plate.
olgreyhair
22
NE PA
Not Bordega bay but still very expensive.
Blower is a Huayi Model hyf8325U120B You can get the factory blower, but they sell for $375 to $499, which seems crazy. It's just a blower motor.
One questions is that I see alot of blower motors with exposed windings. This blower motor is in a full round steel housing like you would expect an electric motor to look like. Does a wood stove put more heat into the blower motor than a pellet stove? I would think so.
