Last night I was a little board and since the weather was cool and damp I elected to stay inside and relax.
I went on youtube and was watching a few videos on building sheds and I came across a Dr.energy video with air sealing, proper insulation installation for attics.
This guy offered the best information, how to advice I've seen in a while. Yes this was more of a 20min promotional video for his business but I walked away with more knowledge, anyone considering adding insulation to there homes should watch his video's first so you can get a general idea of what involved to do it properly, and what to ask a contractor when he / she is giving an estimate.
To insulated an attic space, air sealing is key, this will require total existing insulation removal. start off fresh, then with low density foam you spray beads, much like caulk in a shower door or tile everywhere there's a leak. So all of your top plates, drywall seams, drill holes for electrical wires, registers for heating / ac get sprayed. For houses with hi hat lights you can get roxal boots that go over the hi hat and then sprayed / sealed shut.
Once all the air sealing has been completed then you insulate, it recommended that you use a blown in insulation. For those that need spots in the attic for storage you put foam sheets in that chases that you are covering with boards.
The idea for all of this work is to reduce air seepage / movement, since air is what moves the cold. If you slow the air leaking from the top then the natural stack effect will slow down and you will have less cold filling air at the bottom of your house.
There were move videos on packing hi density foam into wall with existing insulation using a machine and drilling holes in the walls from the outside, insulating basements with natural rock walls, block walls, and pour cement walls.
![[Hearth.com] Air sealing and insulation [Hearth.com] Air sealing and insulation](https://www.hearth.com/talk/data/attachments/197/197313-a215b9eda2a94b52cc82bb34aa11e287.jpg?hash=3IGGM7rcPa)
