Another hearth pad question
PJPellet
588
Western NY
Hi, there is another thread going on this same topic. I didn't want to hijack that thread so I started this one. I cannot find the k-factor of my hearth pad anywhere. On it, under it, around it, online, etc. It is made by American Panel and is a 40" polished copper hearth pad. It cost 310.00. Does anyone have a suggestion where I can locate the k-factor? I just want to make sure I also have the proper pad installed. My Harman P43 says a k-factor of 2.24 or lower is required. Here is the copy and paste from the manual:
Material
used for floor protection must have a k-factor of 2.24 or lower.
Example: 1" thickness of Durock® is rated at 1.92 k per inch,
which would meet the requirement.
I am getting paranoid. Just want the family to be safe as I plan on running the stove 24/7. The installer is useless when it comes to finding out information, unfortunately. Any guidance is greatly appreciated. Thank You.
SmokeyTheBear said:
Contact the maker of the hearth pad.
I've done that but they haven't responded. Hopefully they will.......someday.
My pad has a small sticker on the side that I noticed only because it was peeling off. Different manufacturer. If they don't respond, maybe try calling them?
I didn't think much of it until the OP of the other thread said their vinyl floor was discolored and looked scorched. I used my P61A last night for the first time and only about 2 hours and noticed that the base of the stove gets very hot. I will be switching it for a thermal pad that meets the P61A's requirements.
Well it took almost a week to get an email from the manufacturer, but better late than never. My hearth pads k is 1.83 and that's below the 2.24 recommended. I am good to go. Thanks guys.
The new laws for hearth pads are very strict on requirements of a hearth pad.. Technically K values are gone, period you do not do a rating based on that number. You have 2 types of pads a Ember protection type I and a thermal protection type II, All Harman stoves excluding the XXV and the accentra require the thermal protection pad with approximatly 1.1 R value. Again keep in mind K values are gone so it meeting the requirements of the K value doesn't mean it meets the requirements of the R.. questions? feel free to contact me.
Be safe, fabricate a riser to set your hearth pad on.
Make the riser from a couple layers of Cement board and then just trim the edges so it looks nice.
Two layers of cement board as a backer will add more than enough none insulation to protect the floor/carpet or that's under the main pad.
Many of the makers of the stove/hearth pads simply don't have the info available, and when they will not return calls/emails it tells the sad story.
Good luck
Snowy
