- Aug 20, 2007
- 644
I have a Napolean 1150 which I plan on installing myself. I have had multiple estimates to have the stove professionally installed and in each case was told different stories about what is best.
The stove has a 6" diameter outlet and will be vented from a single story kitchen/family room, through an attic, and straight out the top of the roof. If anybody can help anwering the following, I'd appreciate the input:
1 - 6" vs. 8"? One potential installer said it would be best to tranisiton from 6" diameter stove pipe to 8" diameter vent pipe to improve draft. Opinions?
2 - Single wall vs. double wall stove pipe - the Napolean manual states that 6" single wall pipe should be used (the stove sits atop a hearth that I built which conforms to NFPA 211 code as well as the specifications in the manual); would double wall be better?
3 - Brand of chimney pipe/brand of stove pipe compatability? Another potential installer swore up down and sideways about Superpro Brand for chimney pipe. Opinions? Can one mix brands between chimney pipe and stove pipe?
4 - Extra support brackets for chimney pipe. I live in NE Ohio and it can get windy - that said, I've seen plenty of chimney pipes sticking out of roofs without any extra support brackets. I was leaning towards using them - opinions?
I was originally not planning on installing my own stove, but thanks to all the great information/encouragement I got from this site I did the hearth with no problems and the myriad of different stories I've gotten from potential installers I think I'd rather do the chimney myself as well.
Thanks for advice/opinions
