I bought a soft sided hot tub and was wondering what chemicals i should be putting in it. There are so many different kinds and i couls spend hundreds. What are the basic needs for a hot tub filled with spring water??. HELP
CTwoodburner said:I would not listen to folks who dismiss the entire water chemistry. Yes, you can have good pH and good Cl or Br and good water but over time, other parts, liner or other will wear prematurely. Hardness and Total Alkalinity should be adjusted if out of spec. If this is on a pool, costs could be an issue. Hot Tubs hold so little water, cost is not a major issue here. If this is a softtub, all the more reason to keep the water perfect. Do you know what it costs to have on reskinned??
I agree with some here that pool stores will rip you off on chemicals - there items have a very high markup. I have seen some obscene markup on pumps and filters as well as chemicals. I do understand as they have a seasonal business but it does drive many to the internet and grocery store. Why by baking soda at the pool store for double or triple what you pay at the grocery store?? AS for cyanuric acid - ditto what he said - do not let them sell you that for a hot tub.
Take your water to a good pool store once a month or so for a complete water test - usually free - and then adjust your water. If you do not have a good store near you, find somewhere you can send the water to...
I was fortunate to work for a good service business/store and would recommend them to anybody. Trouble is, they are not all like that. Educatet yourself for sure...
Gooserider said:I haven't actually checked them for hot tub advice, but I would STRONGLY reccomend that you check out TroubleFreePool.com - Since I started taking care of my swimming pool following their advice I have never spent less on chemistry, never had my pool water looking so good and staying that way (even when I didn't test and treat as often as I should have) with minimal hassles... I know many of the TFP folks also have hot tubs, and use similar methods, but there are differences and I'm not sure just what they are....
Remember the pool store has a serious conflict of interest - the easier it is for you to maintain your water, the less they make selling you lots of expensive, high markup chemicals... At TFP, which I consider to be a sort of "hearth.com for pools" we have an expression for many of the newbies that come to us after having spent large sums on chemicals, and still having problems - we call it being "Pool Stored".... In actual practice many of the chemicals pitched at the pool store will do you little good, and some will actually make your water WORSE - for instance the standard pool store dichlor and trichlor will raise your cyanuric acid (CYA) levels - while some CYA is needed in an outdoor pool, NONE is desired in an indoor pool, and in any case, having a high CYA level means you need more chlorine to sanitize the pool safely...
Instead of the pool store, most of the chemistry used by TFP members comes from the local grocery and hardware stores, or Wal-Mart, which costs less, AND we use less stuff...
And, one other nice thing - TFP pools don't have that classic "pool stink" that many pools tend to have - which actually is a sign of problems!
Gooserider
MountainStoveGuy said:goose, i dont know squat about pools, and honestly, im a tub noob. But i do deal with tub customers all day everyday, and the noob status wears off fast. What i do know, is that we want our customers on the simplest, most effective system that fits there tub use. The different sanitizing systems for tubs are for different kinds of use. If our customers are confused , they go elsewhere. We do our best to keep the systems they are on as simple as possible. When it comes to chemistry and DIY, i myself sub alot of products for reef aquariums. A example would be an aquarium product called Kalkwasser. Its pickling lime. I buy pickling lime for 1/10 the cost of kalkwasser. Im all about it, but i am not about to start recommend generic products that have the potential to mess up someones $10k tub to save them a few bucks. Tubs only have about 400 gallons in them, so they get out of whack fast!
